Question about Dryers
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
I've replaced the thermistor, thermostats, and the heating element
George Nava
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Posted on Sep 28, 2014
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: Maytag MDE2400AYW Dryer Heating Elements not staying on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: I have a samsung DV337AEG/XAA Electric Dryer which
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Posted on Mar 25, 2010
Anonymous
SOURCE: DEGX1 dryer will not produce any heat. 5 years
I have the same model of dryer and the same problem and no experience in fixing any appliances. I took a few screws off the top and the front, opened the dryer by rotating it forward, and found a red button (a fuse or breaker?) close to what I figured would be the heat sink. Pressed the button, it clicked, and decided to put it all back together. First load worked fine, hopefully that was all it needed. Good luck and hope this is all you have to do too.
Posted on Jun 05, 2010
Jahn27
Jahn27
  • 1554 Answers
SOURCE: No heat in a Profile
The thermistor at the back of the dryer is the inlet thermistor and it has a normal resistance of around 2270 ohm at room temperature, not zero. A zero resistance means the inlet thermistor is shorted and the control board sees it as an overheating condition and does not activate the heater relay. Replace the inlet thermistor with part number WE04X10111.
The thermistor on the blower housing is the outlet thermistor and it has a normal resistance of around 10000 ohm at room temperature. The heating is good at 17 ohms and inlet safety thermostat and the high-limit thermostat on the heater housing and the outlet safety thermostat on the blower housing must all have continuity.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 22, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: i have a samsung dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 05, 2011
Dle5977w will not heat
Check all Thermostats and fuses. Make sure there is 220v going to dryer. Heat circuit also runs through timer and motor.
Nov 01, 2017 | Dryers
LER6848AW1 whirlpool supreme dryer will not heat at all. All the thurmastats have the proper readings. What do I do now that I've tested them? I have already installed a new element thinking that was...
Hi istine43...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape. Then try to start the dryer and check for heat.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 17, 2011 | Whirlpool Dryers
Is there a way to check the thermostat on the heating coil of a Bosch 500 series dryer with a meter? I've got no heat but I have 240 to the unit and the heating coil has contiunity. The thermal...
Hi mk3327...
Try these solutions to your problem:
Check your Wiring
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse, by removing the wires from each of the two terminals and checking each terminal on the thermal fuse,thermostat,thermistor, ect once you have the wires removed.
Then you do not have to tape the wires together as described above.
Sep 08, 2011 | Bosch Dryers
I've got an electric dryer (GE Model #DWSR463EG7WW) purchased Apr. 2010. It is tumbling but is not heating up. Any ideas for what could be wrong? We've turned the circuit on/off and that didn't...
Hi Zippy478...
Check your Wiring
Sep 01, 2011 | Dryers
Wont heat up. if the thermostat has gone bad will the heating element work
Hi texasjul4...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jul 20, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Model # REL4632BL2; Dryer stopped heating. Replaced heating element, what next?
Hi abelem...
Check your Wiring
Jun 29, 2011 | Roper Dryers
Model # M83121140- Dryer will not heat up. Is there a heating element that needs to be replaced?
Hi jackstraw295...
Check your Wiring
Jun 20, 2011 | Kenmore Dryers
I have a hotpoint dryer and the problem that I`ve been having is my dryer just stops running and won`t start again until I reset the breaker box.Whats causing this?
Check your Wiring
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
Jan 15, 2011 | Hotpoint Dryers
Dryer doesn't heat up
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For further instructions on how to replace the element go to the following website:
This is a FREE answer, Please rate me
Oct 02, 2010 | Whirlpool Dryers
No heat
Oct 02, 2010 | Roper Dryers
Dryers Logo
452 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
