Question about Canon PIXMA MX410 - multifunction fax / copier / printer / scanner color
How do I print a PDf as a whole page instead of 1/4 page? Is there a setting somewhere?
Lawrence Oravetz
  • Canon Master
  • 10,548 Answers
Look at the settings for the printer. Set the paper size to 8.5 x 10
Posted on Sep 25, 2014
My Canon MX420 prints blank pages?
You may be printing a PDF from within a web page and using the browser's print button instead of the PDF reader's built in print button. Just a guess since I'm not a clairvoyant and have no idea what the situation is. Care to fill us in?
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Sep 21, 2014 | Canon Pixma MX420 All-In-One Printer
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
I have been trying to download and print the whole user manual for my epsom dx3800 all-in-one printer... the problem is that when I download it all I end up with is one page - it does have all sorts of...
get the download up again
it should be a pdf version download and that will come up on the screen with page 1/ number of pages
use the printer icon on the pdf page, click on that a print page will come up
tick the pages section and go print pages 1,3,5,7 etc until that last page
click on the print tab after making sure you have sufficient paper in the printer
when finisher pick up the lot of printed pages and reverse and invert back into the printer
no click back on the pdf printer icon and in the pages to print type in 2,4,6,8 etc until the last page
go print and it will complete the book
I feel that the problem is that by only printing one page at a time , you are using the file printer and not the pdf icon printer
May 01, 2017 | Office Equipment & Supplies
Can't print multiple PDF files in 11x17 format. I open windows explorer and select the specific PDF files. Click on File, Print. They all print out, but they all are 8 1/2 x 11 on a 11x17 paper, instead of...
Adobe Reader can be real pain it the... neck sometimes.
But first I would inspect not only the printer setup, but also printer's default print settings. Windows XP has 3 places, where you can see the printer options:
1. Printer properties
2. Print preferences
3. Default print setup.
The third one is the one you have to set. When you double click on your printer icon, a print queue window opens. Choose Printer->Properties, go to Advanced tab, and on the bottom there's a button "Default print setup" (I don't have English XP handy, so I'm translating back to English from my version - excuse me if they might appear a little different).
It's there you need to set up the default page size and so on.
If this still doesn't help, try opening Acrobat Reader, setting the Page Size Scaling to None, printing something and closing Acrobat Reader. From what I've seen, it tends to remember this setting from previous sessions.
You may also try alternative PDF readers, like Foxit Reader or PDF Xchange Reader.
Good luck :)
Oct 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Aug 14, 2009 | Kyocera Office Equipment & Supplies
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
Creating pdf from scanner feed
Instead scan all images with standard settings, combine into one acrobat and then apply the settings to whole PDF
Mar 27, 2008 | Adobe Acrobat Professional 7.0 for PC
Hp LaserJet 5 si
Check the print processor settings in the advanced tab of the printer properties. This should be set to Winprint, and not anything else.
May 01, 2007 | HP LaserJet 5si Printer
Canon PIXMA MX410 - multifunction  fax / copier / printer / scanner   color Logo
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
