First make sure it's putting out enough water. There can be enough water coming out to get the carpet wet but not enough that it picks up much water. This is most often the problem to most machines brought in for repairs. If it's putting out enough water and can't pick it up there has to be something restricting the suction. It could be a clog or something is allowing air to leak restricting suction. Inspect the areas where the suction comes from the machine, through the dirty water tank all the way down to the floor nozzle.
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
a few things to try... the water fill pipe that feeds the machine, check the tap at the end to make sure its on full, if it is then turn water off and unscrew pipe from rear of machine and see if connection on machine is blocked or clogged. then usually located at front of machine at the bottom, unscrew the filter to see if its blocked with small change ( usual suspect ) and try.
You probably don't need as much water as you think you do. If you use the HE detergent, it will not suds up like a top loader. The water and detergent are concentrated and uses much less water. The only way to get more water in the machine is to use a larger size wash load option. Hope this solves all your problems for you.
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
