Question about Pride Value Line Revo Scooter 3 Wheel
I am trying to get a Revo mobility scooter to work, the lights work and power indicator shows there is power, but the scooter will not move forward or reverse when you press the lever, what do I check
I am trying to get a Revo mobility scooter to work, the lights work and power indicator shows there is power, but the scooter will not move forward or reverse when you press the lever, what do I check?
Gino Borg
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
Any beeping sounds or flashing Led on the console?
Posted on Nov 06, 2014
2 Related Answers
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Posted on Jun 18, 2009
Dan Hudson
  • 118 Answers
SOURCE: NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Posted on Jun 11, 2012
Put in new batteries status light blinks no forward or reverse
The blinking is a flash code, maybe you should check the free wheel lever is in the drive position."hard to manually push"
Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
May 31, 2014 | Pride Value Line Revo Scooter 3 Wheel
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Apr 13, 2014 | Ctm Health & Beauty
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Dan
Jun 11, 2012 | Pride Revo 4 Wheel Scooter
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Revo 3 wheel: will not hold constant speed; batteries recently replaced but did not fix problem
hi, there could be a number of issues,
First check the speed pot, try moving the throttle lever in the upwards or downwards direction while going forward, if the scooter starts to pick up again then the speed pot is worn and needs replacing.
if the motor has brushes check them, make sure they can move freely, some times they stick and cause intermittant speed problems, check the battery conections and make sure they are tight.
If this helps please vote.
Regards
GeWiz.
Jan 05, 2010 | Pride Value Line Revo Scooter 3 Wheel
When moving at top speed, my scooter hesitates at times until lately when it has slowed down to a crawl, then it will speed back up again. The charge meter is in the green area and I am consistently...
hi, that is a textbook problem related to the speed controller pot,
the pot is attached to the lever you move to go forward etc,
to be 100% certain trying moving the lever in the upwards direction while gong forward ? does it speed up ,a new speed pot required.
Regards
GeWiz.
Oct 21, 2009 | Pride Value Line Revo Scooter 3 Wheel
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Pride Value Line Revo Scooter 3 Wheel Logo
354 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
