Question about Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606
My L5C0668TX remote sensor is not sensing the outside temperature. Why?
Acu-Rite Wireless Thermometer
5 Related Answers
Anonymous
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Posted on Dec 01, 2010
Anonymous
SOURCE: I need instructions for my Model 00972 Acu-Rite
flashes continuously the time and the outside timp
Posted on Jan 09, 2011
gusgelpi
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
Posted on Feb 03, 2011
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer (model 00754)
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Posted on Mar 02, 2011
fixya-surfer
Sys Admin
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
How do I set the Clock on my Acu-Rite 00604RX
Hi Mona,
To set the time on your 00604 thermometer.
Press and Hold the Time button until the Hour begins flashing.
Release Time
Press and Release the + or - buttons to adjust
Press and Release Time and the Minutes will flash
Press and Release Time to lock in your setting.
Sep 25, 2014 | Acu-Rite Acurite Wireless Weather...
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Jul 19, 2012 | Acu-Rite Acurite Wireless Indooroutdoor...
Lost instructions for my ACU-RITE model # 1097B MAIN wireless thermometer and need to reset it.
I have a acu-rite weather station and it keeps blinking even after changing batteries, is it garbage now or can it be saved
Sep 23, 2011 | Measuring Tools & Sensors
I need to reset the time and do not have the instruction manual.
I Have a Acu-Rite Acurite Wireless Weather Thermometer 604RX and it came without an instructions for use. Is there any web site I can go to in order to get the instructions or could you e-mail them to me? Thanks, Pat
Apr 26, 2011 | Acu-Rite Acurite Wireless Weather...
I need a manual for Acu-Rite Clock/therm./hygrometer #00592w. Can you supply one?
Dec 14, 2010 | Acu-Rite Acurite Wireless Weather...
Acu-Rite Wireless Thermometer indoor/outdoor, the only identifying number I can find is inside where the batteries go, a sticker says: 0417. Question: 1) On the indoor piece, I can set the clock to the...
Before attempting to set the time, let the outdoor transmitter sync with the indoor receiver. Once that's done, you'll be able to successfully set and retain the date and time.
Jan 14, 2018 | Acu-Rite Acurite Wireless Indooroutdoor...
I need a manual for an acu rite 00754 wireless thermometer. Where can I go?
http://www.partshelf.com/acu-rite-instruction-manuals.html
Oct 10, 2010 | Computers & Internet
Acu-Rite Acurite Wireless Indooroutdoor Thermometer 00606 Logo
236 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
David Gust
ray gallant
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
