There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
SOURCE: My Dyson vacuum brush does not rotate even though the
Hi its Darran at Dyson.
Please contact our Helpline on 1866MYDYSON as it sounds as though we may need to arrange for the machine to be repaired. One of our advisors will be able to run through some checks over the phone with you so please ensure you have your machine with you when calling.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
CARPETS OR HARD FLOORS
ā¢ The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
ā¢ The brush bar will not rotate when the appliance is upright.
ā¢ To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
ā¢ The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
ā¢ Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
ā¢ Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
ā¢ The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
