Question about DISH Network Televison & Video
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
Ican get sound through my sony home theatre from dish. but dont know how to hook it up to my 55in sanyo. cant get a picture.
Barry Barrett
    Scholar:
    New Friend:
  • 73 Answers
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Posted on Feb 28, 2015
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: hook up
I'd connect the dish network receiver to the TV's "in" ports and then use an RCA cable to connect the TV's out ports to the onkyo home theater's in ports. It should look something like this:
DVR out -> in Sanyo 42", Sanyo 42" out -> Home theater in
Make sure you don't accidentally plug the cable into the out instead of the in as then you won't be able to hear (and possibly see) anything.
Posted on Jan 06, 2008
Jim Franks
  • 374 Answers
SOURCE: i changed out a tv and dont know how to program without a recieve
If you have a 311 receiver or any single/solo receiver than you will need to put the new set on channel 3. If you a have a duo receiver try 60air or 73cable. Thanks for using Fix Ya.
Posted on May 04, 2009
Jim Franks
  • 374 Answers
SOURCE: Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
Posted on May 18, 2009
SOURCE: whad code do i hse to control my sanyo dp19649 tv
Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
Posted on Sep 08, 2009
raycalo
Ray Calo
  • 358 Answers
SOURCE: I bought a Dish remote for a2nd tv and cant get it
strmason,
Are you still having problems with programming the remote to your receiver? I am assuming it is TV 1? You should have a green tab at the bottom of the remote with a "green 1" and no lettering after the 1. If you have the correct tab on the bottom, you should be on the "System Information" screen, showing on your TV, from the receiver. At the bottom of the screen you will have "primary and secondary remote addresses" with numbers in the white boxes. You can press the "record" button on the remote to address the remote to the receiver. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 08, 2011
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Passing HDMI signal fro cable box to yamaha RXV463 to Samsung HDT
It sounds like a resolution problem to me. Try adjusting the video settings on your set. It may need you to switch modes as some TV's do this (Why I dont know). I have found that even sometimes its the cable service to blame.
Mar 22, 2009 | Yamaha RX-V463 Receiver
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
[email protected]
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Is-lcdtv32 and Home Theatre
run all of your components through the stereo first and just bring the video out of the home theater
thanks
scott
May 29, 2008 | Insignia IS-LCDTV32 32 in. Television
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Feb 10, 2008 | Sony DAV-IS10 System
Hook up
Jan 06, 2008 | Televison & Video
Connet to pc
Well, I would have to know what connectors your sound card and home theatre system have. If you dont have a sound card, get a headphone/3.5mm trs plug to stereo rca plug adapter usually available at your local radio shack or walmart, and connect to the red/white rca plugs on your reciever. If they have other connectors(your sound card/ home theatre system) you might try coaxial digital audio-S/PDIF or optical S/PDIF.
Dec 25, 2007 | Durabrand HT-3915 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
101 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
