Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
<!-- from fixya rte -->Leak at the bottom of freezer - Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 | Freezers
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
I have a freezer that ices up about 12inches from the bottom model#HCMO5OEC and will not freeze the food
your freezer has a freon leak and the leak would need to be found, fixed and recharged for it to work again...
this would cost more then a new freezer...
heatman101
Aug 17, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
Sep 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Water leaking at bottom of freezer door where water line goes into door
DRAIN IS STOPPED UP! IS THIS A TOP AND BOTTOM OR A SIDE X SIDE?
Apr 27, 2009 | Freezers
Freezers Logo
127 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
