I get a striped picture and no sound when I click on Play. Cannot find anywhere to buy head cleaners for Panasonic Video Camera PV-GS300
You can still get mini-dv tape cleaners on Amazon.
Sony DVC Cleaning Tape Discontinued by Manufacturer
SOURCE: Video playback is distorted and has no sound
Usually head cleaner tapes do not do much more than wear the heads out and move the dirt around or in some cases if it is an old tape it may add dirt to the system!!! Someone needs to remove the cassette cover and clean the video drum, tape path, pinch roller and capstan with denatured alcohol. Do not use anything but 100% alcohol as anything else will have contaminates in it. The video head pole pieces are extremely small (we're talking microns) and can be plugged easily. Cleaning the tape guides, audio heads, erase head, capstan and pinch roller is pretty straight forward and the same as any audio deck. Using a lint free Q-tip (or special head cleaning sticks from electronic stores) dip in alcohol and remove any dirt etc from the pieces. Cleaning the video drum is a little trickier. Using the same kind of cleaning stick dipped in alcohol, gently wipe around the video drum assembly. Never, ever go up and down across the face of the head or you could break the video heads!! If you do not know the proper way to do this you should take it to a qualified tech or you could do more damage than good. If you clean your unit the way that I described it should be fine. On occasion I have had a unit with a clogged head that requires a different technique to clean but you would not be able to do this. If cleaning does not work you will need to take it to a repair shop for service. Good luck.
SOURCE: sound but no picture.
if you are able to playback previously recorded cassette and the picture is perfect then its not the head. then the problem is with the image grabbing section i.e. the CCD. May be its damaged and needs replacement.
SOURCE: No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
