Canon PowerShot A3400 IS 16.0 MP Digital Camera with 5x Optical Image Stabilized Zoom 28mm Wide-Angle Lens with 720p HD Video Recording and 3.0-Inch Touch Panel LCD Silver Logo
A
Anonymous Posted on Sep 24, 2014
My canon 5x optical zoom 16.0 is telling me Memory card locked
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Sep 26, 2014
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428951
Points
622693
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
The camera says the memory card is locked what do i do
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Memory card error
First try reseating the memory card, then try formatting the card using the camera o/s if that doesn't work replace the memory card
FUJIFILM FinePix JX500 digital camera says memory card protected
Hi, i've bought a new canon camera (powershot
You probably need to move the small switch on the memory card to the open position.
My Camera keeps saying write protect and my memory card does not have a locking tab
If the slide switch has broken off then the easiest solution is to get a new memory card.
How to format kingston 16GB/Go
Hello, Check the user manual to see if this model if this model even supports a 16 gb card. Some models do not support these high capacity memory cards.
1helpful
I have a Kodak Z990 easy share camera and memory card is protected came up and said reset switch on memory card. How do I reset memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
When i turnon my coolpix s550 screen shows the messaga memory card is write protected i try everything do nothing can you pl tell me the problem thanks
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
Can someone tell me what to do when my GE 5x optical zoom 14.1 megapixel A1455 digital camera will not let me take pics or anything. It keeps saying (Write Protect) whenever I try to take pics. Please...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
2helpful
Hp photosmart that keeps saying card locked when inserted
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
