Special screws prevent the cover removal
SOURCE: Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
SOURCE: Sharp Microwave - R-1481
Yes. We regularly repair these control units for
customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At
our site, we now have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: The lights under the my Sharp Carousel Microwave oven do not work
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week.
At
our Web site, you can get details of our service, plus we have a video
This can often also
full model number) for more information & help.
We're
William E. Miller
[email protected]
SOURCE: Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
