Question about Cell Phones
How do I freeze crab apples
How do I cut up and freeze crab apples right from the tree to make apple dishes later
  • Cell Phones Master
  • 10,543 Answers
Cut them up for whatever use you have in mind (pie, etc.) Put them in a plastic container and add some lemon juice. That will keep the apples from turning brown. Then pop on the lid and put in the freezer.
Posted on Sep 24, 2014
Steve L
  • 85 Answers
SOURCE: when i turn on iphone it freezes at apple logo
try to restore your iPhone.
When the iPhone is powered off, plug into your computer holding down the HOME button. Then restore your iphone.
This should fix it.
www.mobileease.co.uk
Posted on Jul 13, 2009
Do apple trees get viruses like the Maple tree?
Unfortunately apple trees are as prone to virus as any other tree and some specific to apple trees alone. If you do a websearch on something like wikipedia it will probably list a few. Its useful to know the apple variety and also description of what you think is a virus before deciding to try and treat it or cut it down and burn it. Dont put any part of a diseased tree into your compost heap if you have one. Best of luck my friend. List of apple diseases
Oct 08, 2017 | Garden
How do you graft an Apple tree?
go google and type in --methods of grafting apple trees -
Feb 17, 2016 | Dunecraft Grow Your Own Apple Tree...
FULL of errors on iPad2 after latest updates, first from Olive Tree, then Apple
Two possibilities: the app is incompatible with the new updated Apple system, and you'll have to wait for Olive Tree to fix this; or you installed the updates in the wrong order -- maybe you should have done the Apple ones first, then Olive Tree's. Either way you're going to have to reinstall the app. Sorry -- Apple has a history of making software obsolete every time they do a major Mac upgrade; maybe they're doing the same thing with iPod upgrades now.
Oct 31, 2014 | Olive Tree Bible Software iPhone Apps
What can i do to help my pink princess crab tree leaves turning brown?
Older leaves will do this. Keep a proper nutrient balance for the tree, color will respond to nutrients required by tree type. Research your tree. Google it.
Jul 17, 2014 | Garden
What do hermit crabs eat?
  1. You can feed a combination of pelleted Hermit Crab food, as well asfruits, such as chopped apples, grapes and bananas, and vegetables, including dark green leafy ones like kale and broccoli. Pellet-type food can be crushed into powder to feed small Hermit Crabs. Feed one teaspoon for small crabs.
Jul 12, 2014 | Necchi Sewing Machines
What word links crab money and plant?
I can think of two.
Umbrella Crab
Money Umbrella
Umbrella Plant
Would TREE work?
Crabtree
Money Tree
and a Tree is a type of plant
I would go with Umbrella
Jul 02, 2014 | Games
Link word for crab money plant
I can think of two.
Umbrella Crab
Money Umbrella
Umbrella Plant
Would TREE work?
Crabtree
Money Tree
Jul 02, 2014 | iPhone Apps
Can I freeze apples whole or do they need cutting
Please allow me to give you some tips on how to freeze raw apples
Freezing apples will prolong the shelf life, and they will remain fresh for up to 12 months. However, after the apples thaw, they need to be used within a day or two because they will deteriorate quickly.
1. Select ripe sweet apples without large bruised areas. Apples that are firm will be easier to peel.
2. Rinse the apples under cold water. Dry them off with paper towels.
3. Dissolve 1/2 tsp. of ascorbic acid into 3 tbsp. of water. You will need 1/2 cup of sugar for each quart of peeled and sliced apples.
4. Peel the apples to remove the skins. Remove any brown spots from the apples with a sharp knife.
5. Remove the core from the apple. An apple corer will work best for this task; they are available at most grocery stores. Slice the apples into 1/4-inch to 1/2-inch slices. Remove the seeds, stems and hard areas of the apple.
6. Combine 1 qt. of apples with 1/2 cup of sugar and the ascorbic acid solution in a large plastic storage bag. Coat the apples evenly with the sugar and solution.
7. Pack the apple slices into freezer containers. You can also freeze the slices on a cookie sheet and then pack them into containers to prevent them from sticking together in clumps.
Thanks for consulting FixYa
Good day! : )
Sep 07, 2011 | Refrigerators
While trying to install OS10.5 and it will attempt to but it freezes, you the Apple booting circle it stops.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
May 20, 2009 | Apple Computers & Internet
Cell Phones Logo
112 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
