Sews more slowly than normal
SOURCE: My pfaff 7530 was working
Clearance in bobbin area is small and it gets lint balled up in there. If polyester lint, it could even have melted and welded the space tight. Try turning handwheel backwards...really hard...and it will usually loosen up, then clean out the bobbin area. If you have compressed air, use that to blow it out.
SOURCE: PFAFF QUILT AND CRAFT PRO 7530 LIGHT BULB REPLACEMENT
Found "Discount Sewing Mahcine Sevice", 9112 Greenridge Lane, Bloomington, IN 47401, part number "Light Bulb #676". They were $1.95 each, add shipping. Bulb is a little different, but fits fine and seems to have good life.
Paintbox
SOURCE: Viking 936 Serger- handwheel will not turn properly
hi there,
this type of problem related to "overload protection" the motor can't overcome the load work,then it would able to stop your machine,theres problem on motor assembly try to check the carbon brush.if worn out replace,handwheel are couple to motor pulley inside machine.there an opening for the belt.if you want to check it loosen bolt cover,have move the belt you can figure why handwheel moving tight.if you realease the belt handwheel will move independently but handwheel is connected to a cam shaft w/mechanical link connected such as gears,cam and bushing that
can also suspiciuos of obstruction can came there.take this to service center if trouble link to mechanical problem.have a nice day
rate me and thank's
SOURCE: Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
SOURCE: Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
