F64 will appear if lower oven air switch does not close. If air
switch does not close the mode is cancelled after about 45 sec-
onds.
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
SOURCE: The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
