Question about GE Profile Spectra JGBP90 Gas Kitchen Range
THe left front gas knob sparks the right gas burner.
6ya staff
SOURCE:
Anonymous
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
Anonymous
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
Anonymous
  • 11 Answers
SOURCE: General Electric stove top burner does not light
Sorry for apparently not giving feedback earlier, but the gas valve on the one burner has been replaced, and that solved the problem. What apparently caused this is someone forcing the knob in the reverse direction that broke something in the shaft. It sort of worked for a little while, then would not work at all... no gas coming out = no ignition. I replaced the gas valve with the suggestions given above and all is well.
I you are having problem with your unit, check to see if gas is coming out at all from the burners...you will be able to smell it easily. Then find the pinhole on the side of the burner that is used to ignite the burner when the spark is sparking. clean this pinhole out with a toothpick or small wire...really make it clean as small obstructions can prevent it from working. Then clean off the small electrode with fine sand paper and use the toothpick to remove any food particles on the electrode and the insulator around it.
Now looking again at your comment - no ignitor-... if this means no spark, clean the electrodes ...if itstill doesnt work , one of the gurus can specify the component that generates the spark(s) and troubleshooting procedures for that.
To the person who had no gas, that sounds like a main gas valve problem (regulator?)... resend that question to the gurus as you seem to have something blocking the regular flow of gas for the whole unit.
good luck
Posted on Sep 25, 2008
Anonymous
SOURCE: GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Posted on Dec 30, 2008
Anonymous
  • 135 Answers
SOURCE: burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Posted on Feb 05, 2009
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Kitchen Ranges
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
1) Right rear burner electric spark always arcs no matter which of the four gas knobs I turn. 2) Right front burner electric spark only works (arcs) when left two burners panel is unplugged or removed.
Sure. Once we realized that you'd charge a fee, we went to our local brick and mortar appliance repair store and got the info needed for free. What happened to free advice?
M
Dec 02, 2008 | Amana Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
156 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
