I hooked the ant. line to the in line on the Emerson unit , then hooked to the out line of the Emerson unit .From there to the in on the back of the Vizio TV. But I can't get anything to work. The TV. play's but the vcr dvd 'or dvr won't play or do anything. what I'm I doing wrong?
The TV RF cable does the TV radio frequency from the antenna
so it comes from the antenna to the
EWH100F
then it is split so part of the rf goes to the ewh100f and the other part goes from the ewh100f to the TV antenna .
So when you want to record TV on the EWH100f it uses the antenna in rf signal via a built in tuner.
When you want to watch TV the ewh100f feeds part of the RF signal to the TV via its built in tuner.
If you want to watch TV via the ewh100f or watch DVD's or watch recorded shows you need to connect the AV out to the AV in and then switch the input source on the TV to AV.
If the cable is yellow (video)and the other two are red and white (audio) plug this into the same av in on tv.
looking at the back of your ewh100f it is the second last lot of sockets from the right hand side.
SOURCE: Magnavox MWR20V6 DVD
I purchased a Magnavox MWD7006 and need to have it play in Db5.1 KOSS Entertainment system; thus far only plays in stereo; anyone know what I'm missing? I'm using a S-Video cable.
SOURCE: dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
SOURCE: Emerson VCR and new TV don't hook up
i have a emerson vt2522da tv/vcr i do not have a remote and would like to know how to get my ps2 to work on it without the remote
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
