St 9400c keeps cutting out and turning on rapidly boiler will not heat properly
Tom Palicke
    Habit-Forming:
    New Friend:
  • 47 Answers
Rapidly? seconds or minutes.
Make sure you select hot water boiler in the thermostat setup. That can cause short cycling. Boiler need a longer cycle range. If not, remove stat and jump wires, Isolate the problem, is it stat or boiler?
Posted on Sep 24, 2014
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
We seem to have developed a problem with our boiler, worcester 20/25 heatsave. Every time we turn on a hot water tap, when we turn the tap off, there apears to be a loud noise from the boiler or pipes for...
it seams the valve that senses water flow is not operating properly,causing the boiler to keep heating the water when it has nowhere to go,i,e the taps turned off,thus boiling the water.
Jan 12, 2009 | Heating & Cooling
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
