Question about DeLonghi EC155 Espresso Machine
Hot water comes out of the machine and stays in espresso bowl. It doesn't drip into cup below
4 Related Answers
Anonymous
  • 230 Answers
SOURCE: Describe your DeLonghi BAR 32 Espresso
many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
Posted on May 15, 2008
Anonymous
  • 638 Answers
SOURCE: Bar 41 Espresso Machine
the service centre close to tennesse is:
ALL MAJOR APPLIANCE:--and their contact number is :
Call:
901 5263881
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 30, 2008
Anonymous
  • 18 Answers
SOURCE: Espresso machine will not make Espresso.
Also, the outlets on the bottom of the portafilter may be plugged. Flip the portafilter over and look into the outlets. With the inner filter removed, you should be able to see light through the outlets. If not, these may be plugged from improper cleaning. Set the head of the portafilter in hot water for a few minutes to soften the plug, then using a soft wooden toothpick, clean out the jam. Once you get water flowing through, run a few empty shots to finish the cleaning and inspect.
Posted on Jun 11, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Our seven-year old espresso machine is making a
Check the shower screen in the brew head.
Posted on Oct 10, 2009
tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 • Cuisinart ICAPP-4
We have a Axiom 12 cup automatic. We have been having issues with the hot water spiket dripping. Any ideas why and how to fix? Thanks
u mean dripping on the water outlet on top of ur server ? ur dripping solenoid plunger might be already open a bit or ur incoming solenoid valve not closng properly
Won't pump when you put the cup in just a drip tryed diffrent cups but just a drip comes out when there is no cup the water comes out and it is hot
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
8helpful
2answers
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
10helpful
5answers
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
2helpful
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
-Tha Mp3 Doctor
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
1helpful
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
DeLonghi EC155 Espresso Machine Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
