Question about LaCie Computers & Internet
Lacie fuel won,t connect to network
An unexplained error has occurred ,message
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: error message connecting web cam on yahoo messenger
make sure that the web cam attached to the personal computer nor
in remote computer . if it attached to the remote computer it may have permission problems.
Posted on Dec 14, 2007
Anonymous
SOURCE: psp internal error
I try to apply a theme and it says an internal error occurs. It freezes when a game starts off my memory stick, then it freezes when i leave the game
Posted on Jan 07, 2008
Anonymous
  • 121 Answers
SOURCE: Having problem with external hardrive
Try clicking on the my computer icon and then see if you can see the external drive in the my computer window. Most likely since it is an external drive the drive letter could have changed. If you see in the shortcut before it said E it could have a different drive letter now. Keep me posted and if you found this solution helpful please rate it. Thanks - Tech101
Posted on Jun 24, 2008
Anonymous
SOURCE: Network connection error
thank you so much!
it worked
after like forever of trying!
your the best!
Posted on Jun 25, 2008
Anonymous
SOURCE: login errors occur when trying to use new networks
log in errors problems comes on the solution is the net work ip address is not matched plz find and given correct ip address
Posted on Jun 15, 2009
I cannot drop files from my laptop to my lacie n2870. What is the problem?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Jan 13, 2013 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Server error 500
The adress of the server error is 00:D0:4B:8D:1C:50. Has anyone a solution? and The message was " Something wrong with the volume CNID BD"
Feb 29, 2012 | LaCie 2big Network (2-disk RAID) (301257U)...
PC doesn't recognise hard drive connected via front panel usb?
Use one of the rear USB ports. Mind you, my PC won't deal with it when connected to any IUSB port although it's fine when connected to the router. This is driving me mad...
Nov 02, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
Lacie NAS doesn't appear in network
Have you installed the lacie network assistant?
Jan 23, 2010 | LaCie Ethernet Disk (300788) 1000 GB...
I have a message that says , error message: PXE Media test failure chek cable
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
Sep 30, 2009 | Compaq Armada E500 Notebook
I can not send a message to friends Transport error (#1001) while retrieving data from endpoint `/friends/ajax/superfriends.php?all...
Make sure you are connected to the internet and also try resfreshing the page. Let me know how this works.
Jun 22, 2009 | Facebook Social Network
Computer is having trouble connecting to hard drive LaCie 300 GB
That error message usually means the drive is working intermittently (writing to the disk), and drive failure occurs shortly thereafter. You might try a different connection mode (USB?), and make sure you have everything on that drive backed up or copied elsewhere.
May 02, 2017 | LaCie D2 Extreme 300 GB Hard Drive
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Computers & Internet Logo
121 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
