Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
How come my over the range microwave does not turn on at all??
  • Bradford Snelson
    Bradford Snelson Mar 15, 2018
    Thanks for asking this question, I've been having a similar problem with my microwave at home. I don't know anything about microwaves, so I wouldn't even know where to begin looking for any internal fuses. I'll probably just end up calling an appliance service to look at it.
    http://www.capitalcityapplianceservice.c...
Mister Danger
  • Samsung Master
  • 5,631 Answers
Check internal fuse. If it's ok, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. Diagnostics and repair might be quite complicates so better you take it to a repair service. You have some interesting Youtube video tutorials to repair a microwave
How to Fix Microwave Oven Simple Fuse Replacement
Replacing Microwave Fuse Pt1 of 3
Microwave No Power Repair
Microwave Not Turning On Fuse Testing Microwave Troubleshooting Repair
Posted on Oct 17, 2016
Cannot turn microwave off. Help
Only happens when cooking a big pot under the microwave? Hosing thermal fuse / thermostat kicks in to cool the microwave. Is the micro. Installed proper height above the range? Are you using the fan when cooking on the range?
Apr 30, 2016 | LG Microwave Ovens
My microwave over does not shut off
I'm sorry, I don't have an answer, but my radarange also began this odd behavior about a month ago... my son is a mechanic has almost forbade me to use it, stating he gets a headache everytime he opens it.... Once the range stops cooking, I open the microwave to get the food out, and the range immediately turns back on, lights on, and carousel turning! I have NO IDEA if the microwaves are engaged at this point???!!! But suppose I need to find out ASAP!
Oct 10, 2014 | Amana Radarange Microwave Oven
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
My microwave oven turns on but does not heat the turn table turns but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Aug 04, 2011 | LG 2.2 Cu. Ft. Over-the-Range Microwave -...
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
423 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
