SOURCE: Trouble with Fossil ME1014
I looked at a picture of the watch. I see the date. the dial that is right below the hands is a moon dial which does the phases of the moon & below that you have a separate second hand. A lot of times on a watch that looks like that if you pull the crown where you set the watch with out half a click it will set the date if you turn it on way and the moon dial if you turn it the other way. To set the moon dial on the watch you need to put it on the full moon when the moon is full again then it will keep up with the phases of the moon. I hope this helps.
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
SOURCE: Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
