Water Heaters Logo
Question about Water Heaters
I have a new pressure switch but still have low water pressure
indiana650
    New Friend:
  • 49 Answers
The pressure switch shouldn't be reducing pressure unless it is smaller that the water pipe. Pressure switches in water heaters are a safety device that activate when pressure builds up above a pre-defined limit. I'm guessing that the most probable cause of low water pressure is either not enough head into the water heater (this is the height of water pipe) or not enough mains pressure. Your best bet is probably to install an inline circulation pump with a flow sensor. This will automatically detect that water is being used and turn on to boost water pressure.
Posted on Sep 23, 2014
What can restrict water pressure in my water heater?
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/New-water-heater-making-noise.html
Repairs made in water line can clog heat traps on new water heaters.
Old plumbing can have sediment at elbows.
DIY resource links above.
Otherwise call plumber.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My AMTROL water well tank is copying the pressure of the prussure switch
Sand the points on the pressure switch
Replace pressure switch
http://www.amazon.com/dp/B000BQSERE/?tag=waterheaterti-20
Test you are getting 240Volt to pressure switch
Turn breaker fully off and then fully back on
Replace control box or replace start capacitor:
http://www.amazon.com/dp/B0060C7GFO/?tag=waterheaterti-20
Drain tank, and replace the air valve
http://www.amazon.com/dp/B000BQYKJK/?tag=waterheaterti-20
Gene
Low water pressure
Copy following link for low pressure troubleshoot.
Requires water pressure gauge on water heater drain valve
1helpful
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
I am on a well system (submersible pump) and low pressure issues happened this week. Checked the pressure on Smart Water system and it was 45psi. I replaced the paper filter with a carbon filter cleaned...
This could be caused by several different issues. A faulty switch on the well, bad well tank, bad check valve. If you have a water softener, bypass it to see if pressure loss is through it. That carbon filter will cause even more pressure loss. Turn a cold water faucet on, let the well cycle several times and observe the cut-in and cut-out pressure. Typical well pressure pressure will be 40-60psi.
RJ
4helpful
3answers
Triton opal shower showing low pressure,when there is no low pressure!
In the top of the water inlet valve at the bottom of the unit there's a plunger that rises when the water is switched on. this activates a small switch at the bottom of the pcb and cancels the low pressure warning. this is free to turn in the valve and over times may rotate stopping the plate on the top from contacting the switch on the pcb. If this has happened just turn the plunger back to the correct position.
1helpful
2answers
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
