If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
SOURCE: There is a message in front of my picture on the monitor
When viewing pictures in playback mode, simply turn the index finger dial (up by the shutter button) and this will change the 'mode' in which you view the pictures and should eventually get you to a setting where this information disappears.
SOURCE: aperture priority malfunction
davidsucklin,
You can use the film lens with the D80, but it it not react to the same settings as it did with the film body, the multiplier factor for the focal length is going to be different and it may be stopped down a bit. When you are shooting in aperture mode are you adjusting your shutter and ISO? The camera and the lens have to be communicating the same info to one another inorder for it to work. First set the camera back to auto mode the check the shot to see the settings (f-stop, shutter speed) test them with different ISO's to see what the camera thinks the settings should be, then go back to manual on the camera and lens and try the shutter priority mode with the aperture ring set at the 2.8 to see if it works then change to Aperture mode with the same settings that can take the picture. If it doesn't work keep in mind som of the older D lenses will drop some functionality (like aperture) in certain configurations. You can verfify compatibilty of your specific lens on Nikon's support site.
randy320sgi
SOURCE: Can't get F3.5 aperture on the 18-135mm kit lense on d80
You may be shooting auto and there is too much light. If you want to be sure you are shooting with 18mm @ f3.5 then shoot with aperture priority (the shutter speed will adjust automatically). Ususally at a wide focal length you would want a small aperature (smaller f-stop) so this should not really be a problem.
SOURCE: fEE error code on nikon d80
To solve this all you need to do is turn the lens' aperture ring (the one nearest the camera body) to the smallest number (probably 22 or 32).
SOURCE: Aperture stopped working on Nikon D80
This could be caused by dirty contacts between the lens and the camera body. Also could be a lens problem. Look at the small round contacts on the lens and the corresponding contacts inside the top area in the body (with the lens off). If they look dirty or discolored (should be silver and somewhat shiny) then clean up with a Qtip or VERY CAREFULLY with a clean pencil eraser. Don't get any eraser dust inside the lens or body. With a DX lens, there's not too much else that can go wrong, other than a lens problem.
