Radio Communications Logo
A
Anonymous Posted on Sep 22, 2014
How do i fix heap error 221521 ; 221c on pro 106
John Nolan
Level 2:
Sergeant:
  • Expert 347 Answers
  • Posted on Aug 02, 2016
John  Nolan
Expert
Level 2:
Sergeant:
Answers
347
Questions
0
Helped
73567
Points
601
That means that you have a trunking system that has no sites assigned to it. If you do not have a 3rd party PC software, download PSREdit 500 from here ( 30 day free trial) Upload to the program then back to the radio and it will clear the heap error. http://www.psredit.com/psredit500/download.html
1 Related Answer
Ironfist109
Iron
  • 3018 Answers
  • Posted on Oct 07, 2011
SOURCE: heap error message on a pro scanner 106. heap
  • Turn the scanner on.
  • Press "0"
  • Press "1"
  • Press "ENT"
  • Now press any key
  • Now press any key again.
  • Somewhere along the line you programmed a talk group into your scanner that does not have any association with any trunking system and your scanner did not like it. You can either find the codes and erase them individually or the hard reset (reset to factory default) by following the steps above.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
How To Fix Roblox Error Code 106?
Some Roblox players report that every time they try to join a friend, they get the error code 106. The error is reported on Xbox One and usually occurs for people who first try to join an online session. Read blog for solution
I have a radio shack pro 106 scanner.it is coming up heap error 21c321.What is this and how do I clear the error/
that means that you have a trunking system that has no sites assigned to it. If you do not have a 3rd party PC software, download PSREdit 500 from here ( 30 day free trial) Upload to the program then back to the radio and it will clear the heap error. http://www.psredit.com/psredit500/download.html
Pro-106/pro-197 digital trunking radio scanner appendix B: Detailed Menu Reference book
  • Hope this helps.
Regards, Tony
3helpful
Heap error message on a pro scanner 106. heap error 21DB1F: 21E2 how to correct this issue
  • Press "0"
  • Press "1"
  • Press "ENT"
  • Now press any key
Regards, Tony
3helpful
When i tried to connect idea net it shows error 106 error_internet_disconnect.i had uninstalled the antivirus but still the probem exists.
Error 106 occurs when there is a problem with Microsoft Windows. The Error are often critical system errors caused by corrupt and missing registry data. This error must be fixed immediately to prevent further damage to the Windows, such as system not responding, blue screens, can't open programs...
kindly use system registry cleaner to fix it use Reginout tool in order to fix registry errors...
1helpful
Suddenly i have encountered the problem of error 106 internet not found
Use Reginout cleaner in order to fix registry errors
1helpful
I am getting an error message when I try to activate voice dial on my sanyo pro 700 mobile phone "Heap Free Error" Then the phone restarts after a minute.
Hello my friend,this a programming error,probably your phone software/firmware is corrupted.You should try to reinstall your firmware or take it to a repair shop.
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
