2007 Hyundai Getz 1.4 Logo
A
Anonymous Posted on Sep 22, 2014
Why does malfunction light come on & car misfires/pinks randomly?
Sometimes pinks without light coming on?
Lawrence Oravetz
Level 3:
  • Hyundai Master 10,558 Answers
  • Posted on Feb 14, 2016
Lawrence Oravetz
Hyundai Master
Level 3:
Answers
10558
Questions
Helped
2699927
Points
29284
A misfire condition will trigger the malfunction light to come on. Other engine malfunctions will do it too. Have a diagnostic meter connected to find out how many codes are generated so you will know what other problems may be happening.
1 Related Answer
Anonymous
  • 225 Answers
  • Posted on Nov 03, 2009
SOURCE: random misfire on cylinders 1,3 & 5, 2001
changed out spark plugs/wires and possibly the distributor cap
I have an 05 Suzuki Forenza that has a flashing check engine light. This started on Tuesday. Had the codes looked up. Car is driving shaky and dash lights are blinking. Any ideas?
fix the anti freeze leak --before you blow a head gasket
what your codes mean
Check Engine Light On, P0300 Random Misfire Code. A random misfire means your engine is misfiring, but that the problem is not isolated to one or two cylinders. It is jumping around in a random way from one cylinder to another. A random misfire code usually means the air/fuel mixture is running lean.
What the P0700 code means. P0700 is set when the PCM detects a malfunction in the transmission control system. This malfunction causes the vehicle to set a Check Engine Light and trigger a failsafe mode. Once the failsafe mode is set it will remain until the fault is repaired or normal operation is detected.
PO133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
3helpful
I have a 2007 Holden viva 1.8 Auto Ever since I bought this car engine warning light comes on randomly. Bought a code reader and P0700 cnf comes up with p0300. Fits as the symptoms are when booting it...
code PO700 transmission control system malfunction. code PO300 random multiple cylinders misfire detected.possible could have bad spark plugs,clogged fuel injectors,faulty ignition coil or coils.low cylinder compression.
Random misfire cylinder 3
Smoke test entire vehicle for vacuum leaks
You don't have any idea where the misfire
is from, at this point,find out
You installed parts
That is not what you do,you diagnose & find
the cause of the misfire,no parts involved there
You don't have the professional tools or software
at home, to diagnose without wasting time & getting
no where
Could have a bad intake gasket or mechanical problem
in one cylinder
2answers
After going over 40mph the check engine light goes on n it gives the code 440
How did you read that code on your car? A 92 Accord is supposed to give you pre-OBD honda codes, which are all below 100. Please check the code again and re-post it.
4helpful
3answers
P0300
P0300 is a random missfire code. What exactly would you like to know about it??
1helpful
2006 Dodge Quadcab 1500, 4.7L. Ok I have changed the spark plugs & coils, oil, oil filter, and air filter....my check engine light is still coming on. Ran diagnostic at store, PO300 coming up (said...
Random misfires are some of the trickiest problems to solve, usually an ignition system problem a bad or weak coil pack or possibly a spark plug wire. If not the ignition system then surely a clogged injector.
4helpful
2answers
Car runs greAt BUT FLASHES LITE PO300 P1781
P0300 is a random engine misfire code. P 1781 is a transmission code, but it refers to a malfunctioning engine speed signal (crankshaft angle sensor). A bad crankshaft angle sensor or camshaft angle sensor can cause the P0300 code. A large list of items can cause a P0300 code, but since you have both, I'd be checking the crankshaft angle sensor and the related circuit. Sometimes, the mounting screws loosen up, which can cause the sensor to not function properly, all the time. Get this fixed, because over a period of 4 to 6 months, this can destroy the catalytic converter in the exhaust system ($$$$)
Charlie
2helpful
2answers
98 camry engine light on w/misfires & system too lean
take sample of your fuel into clear plastic bottle from fuel line
is there any water present?
this can cause these codes and then not go on storing codes for other bank even though that bank will be missfiring also due to water & P0300 Random/Multiple Cylinder Misfire Detected being logged
check all connections to coils/leads & wiring connectors
due to miss fire codes for cyl 1,3,5 all on the same bank
also look and check for air leaks on that bank (hose knocked off or splithose)inlet manifold gasket,brake booster etc...
3 injectors being blocked slightly on same bank posible!!!
check wires and signal
was it running like this b4 tune up & repairs?
this is what codes are
P0170 Fuel Trim Malfunction (Bank 1)
P0301 Cylinder 1 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0305 Cylinder 5 Misfire Detected
the last code is for trans due to misfire/running lean on bank 1 probably a torque problem code
2helpful
What is rundam misfire
To my knowledge, random misfire could be described as failure of any of the sparkplugs to fire in an unpredictable manner. A misfire is any of the plugs not firing but in a given time period, predictable. Random misfire on the otherhand comes and goes, sometimes it misfires, sometimes not. This is often an indicator of a loose electrical problem which is intermittent in nature.
The error code P0300 pertains to the above described random misfire or in some instances multiple misfire. The last digit (except when zero) wold points to which cylinder is not firing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
