When the HDMI 1 is connected an error message says not supported and get the same message for HDMI 2.
SOURCE: Dynex 19 LCD
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
SOURCE: New 40 in Dynex having issue
Just got off the phone with Dynex, sounds like a common problem with a recent batch.
Tech support suggested returning the tv to futureshop/bestbuy since I'm within 30 days of purchasing.
SOURCE: i have a dynex dx-lcd32-09 and the remote stop
Since both remotes are working this failure could be due to a defective infrared receiver on the TV. This device is located on a small board where the LED is connected.
Let me know if you require further assistance.
