Casio Exilim EX-Z750 Digital Camera Logo
A
Anonymous Posted on Sep 22, 2014
File:///C:/Program%20Files%20%28x86%29/CASIO/Photo%20Loader/library_1.htm ? Button Few?
When i klick Button Few or Betrachten, i will read this: file:///C:/Program%20Files%20%28x86%29/CASIO/Photo%20Loader/library_1.htm
john cordey
Level 3:
  • Master 730 Answers
  • Posted on Sep 23, 2014
john cordey
Master
Level 3:
Answers
730
Questions
0
Helped
206203
Points
2287
This is just the path to the library file, this is where Casio store images automatically.if you want to download photos from sd card while camera is connected keep the camera switched on ,connect cable,go to computer ,the camera should be listed.Then transfer to C:/picture folderYou may need to use an install disc,if you don't then obtain a card reader ,remove card from camera and download across that way.if you need to transfer images off the cameras memory then camera needs to be connected.
8helpful
6answers
How to recover lost file on memory card?
you can recover lost file on memory card with memory card recovery software
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech data recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
2helpful
2answers
Hi, My wife dumped our pictures in to our computer under another format than jpeg. I would like to change our pictures to jpeg. Someone told me all I need to do is punch a few keys and my pictures would...
You need to read each picture into one of the picture editing programs like Adobe Photoshop, or Corel PhotoPaint and then export them in the desired format.
Investigate what photo editing software might be on your machine.
4answers
How do i recover deleted images from the internal memory of the SOny DSC-W30?
Luckily, there are many software applications that can help you recover your lost digital photos. Pictures can be recovered because when a photo is deleted from a memory card, the link to the photo is removed, but not the actual data. You can think of it this way: you go to a library and look up a book in the database, but don’t find any information. Maybe the book was new and had not been put into their online system yet, but the physical book is still in the library, you just can’t find it easily.
Photo recovery programs because ignore the link and read all the books in the library and just spit them back out for you. They usually work very well unless some serious damage has been done to your card. One program that I have used, which does an excellent job and is totally free, is ArtPlus Digital Photo Recovery.
The program is only 1MB in size and doesn’t even have to be installed on your computer, it just a single executable file. To recover your photos, first connect the camera to your computer or use a card reader. Download the program and run it.
Go ahead and click Run Digital Photo Recovery at the top. Click Next and choose the drive for your memory card:
digital-photo-recovery.png Next choose the target folder where you want to save the recovered photos:
recover-photos.png Finally, go ahead and click Start to begin the process. Depending on the size of your memory card and your computer’s speed, the process can be anywhere from a few minutes to several hours. Either way, I’m sure the waiting time will be worth it!
photo-recovery.png I’ve tested the program by simply deleting all the photos off of my memory card (of course I saved them first) and running the program to see what it could recover. I was quite impressed with how well it worked! I was able to get back more than 90% of my photos. The other 10% were a little messed up and some were just empty files, but most came out perfect! Give it a shot and hopefully it works!
2answers
How to retrieve folder contents deleted during an uninstall
To recover pictures from your harddrive you can use the program found [here].
It's a try.before-you-buy program, so you have a couple of days to try it out for free before you have to buy it. I presume you don't need more time than that.
Before you download and install, think about using another harddrive to save the file to, and to install to, since installing it on the same harddrive as you stored your pictures on isn't so good. If your unlucky, the program can install on the same space on the harddrive as the pictures lay, and in doing so, make it harder to get back the pictures.
Cheers
Error message when accessing internet explorer on the computer
This happens on installing vista the first time If u can install despite this message(ignore), then restart in safe mode and if your Vista is genuine then ask microsoft to send this particular file(SHELL32 if I h'nt forgotten) replace where the original is supposed to be and after that it should be fine. The Only other option is to Install WinXP_SP3 & enjoy.....sodeep
My Casio Exilim EX-Z57
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
EVERY TIME I use my scanner ie scrips errors involving - file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm comes up
Hi I encountered a similiar problem with my HP PSC 2310 printer recently. "file:///C:/Program%20Files/HP/Digital%20Imaging/Skins/hp1/sc/scan.htm". Following are the soultions provided by HP team. Solved mine using solution #1. Hope this is of help :)
Solution 1:
1. Double-click on 'My Computer' icon on the desktop.
2. Double-click on C:
3. Double-click on 'Program Files'.
4. Double-click on 'HP' folder.
5. Double-click on 'Digital Imaging' folder.
6. Double-click on 'Skins' folder.
7. Locate and double-click on 'hp1' folder.
8. Locate, right-click on 'skins.xml' file and select 'Copy'.
9. Click on the 'Back' arrow to go to the 'Skins' folder.
10. Double-click on 'hp2' or 'oov1' folder.
11. In the folder, right-click on any blank space and select 'Paste'.
12. Now restart your computer and check the functionality.
If the issue still persists, please follow solution 2.
Solution 2:
1. Insert the All-in-one software CD in your computer and cancel any installation screen that may appear.
2. Double-click on 'My Computer' icon.
3. Right-click on the CD-ROM drive that contains the software CD and select 'Open'.
4. Double-click on the 'Setup' folder.
5. Double-click on the 'SkinsHP' folder.
6. Right-click on the file 'SkinsHP1.MSI' file and select 'Install'.
7. Again right-click on the file 'SkinsHP1.MSI' file and select 'Repair'.
8. Restart the computer and check the functionality.
Solution 3: Uninstall and reinstall of the software.
1. Insert the CD that came along with the printer.
2. In the CD contents, you will be able to view a folder named "UTIL".
3. Inside the UTIL folder there will be a folder named "CCC".
4. In the CCC folder, among the various files, you will be able to view four files named, Uninstall_L1.bat, Uninstall_L2.bat, Uninstall_L3.bat and Uninstall_L4.bat.
5. First double click on Uninstall_L1.bat file. A black DOS window will open up. This will uninstall the software by Level 1 method. It will take a while until Level 1 uninstallation is complete.
6. Similarly complete level 4 uninstallation by clicking on Uninstall_L2.bat, Uninstall_L3.bat and then in Uninstall_L4.bat.
7. This completes level 4 uninstallation of the software.
8. Now install the software from the CD and check if the issue is resolved.
Cheers,
kypsyche
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Casio Camera Expert? Answer questions, earn points and help others
