Replaced large drain hose on the bottom of machine. Ran a cycle of clothes it washed, rinsed and dried the cloths. After about 20 min. I went to run another load of clothes and there was water filling up the machine. Lots of water it totally fills up machine. It happened last night and this morning when I open machine water everywhere what could this be from?
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: HE3 front-loading automatic washer
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
SOURCE: Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
SOURCE: Maytag Performa will not drain
If this is a direct drive washer (no belts) you have a bad water pump or a sock has gotten sucked in to stop it up. get under it look for two hoses going to a white looking valve. If you pull the hoses look out for all the water to flood out so be preped. Pull the pump out and ck for sock or fuzz in it then try to turn to trun by hand if its hard its bad. repost if need more help.
SOURCE: washing machine keeps running when on extra large
Leaking pressure switch or pressure hose ,,,or both
