Hi This code usually means that there is no cold fill. If the cold isolator tap has not been accidentally turned off, then most likely the clamp-on pipe has corroded over time and needs changing to a proper isolator valve TEE. The other possibility is that the cold-fill valve has failed. This is the unit that the cold inlet pipe attaches to at the rear of the machine. OR Water hasn’t emptied before max empting time,(drain problem)it won’t spin because of this reason. Thanks for contacting fixya.com
10E on electrolux means water hasnt emptied before max empting time,(drain problem)it wont spin because of this,this could be the same situation even though its a frigidaire
