Are there a button combination to unlock the keypad?
SOURCE: can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
SOURCE: Microwave is locked. It says "Keypad touch locked"
Hold lock button for a few seconds and it should return to normal
SOURCE: Our GE Spacemaker XL 1800 microwave's controls are locked
The
first thing I would suggest is a hard
reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,
leave it unplugged for about 5 minutes.
SOURCE: Control panel is locked.
Pres the "Clear/off" button and hold it down for six seconds. The panel will unlock.
To Turn the Control Lockout Feature On or Off:Process B
- Make sure the microwave oven and timer are off.
- Press and hold the CANCEL keypad for 3 seconds.
- 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
- Repeat to unlock. Again, 2 tones will sound.
Hope this helps?
- Press and hold the START keypad for 5 seconds.
- 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
