Question about Bunn 10 Cup Home Coffee Brewer
Why won't my bunn coffee maker turn on
Bunn coffee pot has been turned off for several months it will not turn on now.
Coffeeman Mike
    New Friend:
    Problem Solver:
  • 8 Answers
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Posted on Sep 22, 2014
5 Related Answers
Anonymous
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
Steve
  • 3289 Answers
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Posted on Dec 02, 2008
Gord Thurston
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
Anonymous
  • 125 Answers
SOURCE: Restart a bunn coffee pot after it being off for 6 months.
Hello. Hope this is what your looking for:
http://www.bunnomatic.com/pdfs/commercial/manuals/33545.0000.pdf
follow the instructions for first setting up the unit, as most, if not all the water has evaporated by now. Don't plug it in yet :)
if not you can go to www.bunnomatic.com and download the appropriate manual, there is a link on the left side of the page, click and choose your unit.
Hope that helps, and thank you.
Posted on Apr 13, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Posted on Jul 01, 2010
I just purchased a new a10 bunn coffee maker and it just doesn't brew a hot pot of coffee. It is warm enough to drink without cooling it like my old bunns and the cup of coffee is almost cold before you...
Plug in brewer and turn on vacation switch on side
of brewer. Allow 15 minutes for water to heat to proper
temperature. This is a quote from bunns troubleshooting page. Also it should be under warranty in which case you could go to www.bunn.com and call their service line and either have them send a tech to look at it or have you send it off for warranty repair. Hope this helps.
www.midstatebeverage.com
Nov 30, 2010 | Bunn BT10B Coffee Maker
The unit brews coffee OK. About 2-3 times per hour, the brewing element turns on and bubbles for a few minutes. This annoys me. Will it shorten the life of the coffee maker? It has done this since it was...
Hi. The pot is turning itself on because the thermostat is telling it to do so, because the coffee in the pot is getting cold. You might try feeling the surface under the pot is sitting on to see if it is hot. if it is not hot the keepwarm element is not working, if so get rid of it and but a heavy duty coffee maker ( Bunn ) It does not pay to repair them because the fright to and fro, plus the cost of the repair. Probably made in China. Good luck. bobbyone
Aug 13, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Bunn thermal coffee pots not keeping coffee hot
If might not be the thermal pot, it is possible it is the machine itself. If you have a candy or meat thermometer, place it in the pot as soon as the coffee has completed brewing. The temperature should be at 175-185 degrees. If it isn't, then the machine needs replaced. If the temperature is correct, then please call customer service with the model and date code to get the thermal carafe replaced. If the temp isn't correct, and it is 3 years old or less, the machine will be replaced for no cost. If it is over 3 years old, it can be replaced at a reduced price.
Jul 12, 2009 | Bunn Coffee Pots: Thermal Carafe
Bunn automatic coffee maker will only make half a pot, this is a commercial unit with 3 burners
try cleaning with white vinegar(50/50 with water)may have calcium deposits supposed to clean once a month-let it soak overnight use coofee filter to catch deposits run numerous times then throughly rinse with water!!! :)
Jul 04, 2009 | Bunn NHB Coffee Maker
Feb 05, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
My bunn is too slow
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn 10 Cup Home Coffee Brewer Logo
268 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Harrie
jasbo
jasbo
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
