Question about Cuisinart Coffee Makers & Espresso Machines
Where is Cuisinart 12 cup programmable Thermal coffeemaker DTC-975BKN water filter?
Find the charcoal water filter
1 Related Answer
taran_2005
taran_2005
  • 10515 Answers
SOURCE: I received a Cuisinart 12 cup, programmable
Unfortunately, there are not much options left. Either you need to keep an eye on ebay. As of now, lid for this model is not available, but it could be there.So, it's worth keeping an eye on it.
Look at :-
http://www.pickeringappliance.com/pickeringappliance_contact_us.html
or contact them at :-
1-866-428-5590
T
hese people usually have the lids. You could confirm the same with them as well.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
PS - Do not forget to accept the solution,if 100% satisfied from my response and close the thread.
Posted on Sep 12, 2010
Why is the coffee spilling/leaking everywhere during a brew cycle?
wrong filter possibly my Bunn does that with non bunn fliters
Apr 14, 2015 | Conair Cuisinart DTC-975 12-Cup...
Filet folded & overflowed. Now coffee maker will not make coffee
Clean your coffee maker with vinegar or as the manual instructs no fewer than 3 times per year, at least 3 times back-to-back if you haven't been doing so regularly. The heating element may be overheating due to hard water deposits, triggering the end-of-cycle shut off.
Apr 12, 2009 | Cuisinart Coffeemakers
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
What is the best way to clean my cuisinart coffee maker?
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart dcc-1150 coffeemaker
To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
-Tha Mp3 Doctor
Oct 24, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart 12 Cup Digital Thermal Coffemaker
I called Cusinart support and they told me to fill with 2 cups of white vinegar and the rest water, let set for three hours. Did that. Had to keep hitting the on button to get this solution through. Then used a solution of one cup of vinegar and water and this ran through the whole cycle. Ran three more with just water and now it works just fine. Brewed coffee this morning with no problem. Didn't think this would work but seems to have solved the problem. They do suggest you decalcify once a month using the vinegar solution...hope I remember to do this as it would be a lot easier than having to get hitting the on button. Good luck!
Dec 24, 2007 | Cuisinart 12 Cup Digital Thermal Coffee...
Kenmore Elite coffeemaker water filter
http://www.kenmore.com/shc/s/p_10153_12605_00869768000P?filter=Price%7C%240-260%5E&vName=Appliances&cName=Small+Kitchen+Appliances&sName=Coffee%2C+Espresso+%26+Tea+Makers
Try here. Hope this helps.
Oct 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
104 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Charles Tidwell
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
