He3 electric dryer
SOURCE: Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
SOURCE: My kenmore elite he3 electric dryer control panel
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
SOURCE: Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
