Question about Maytag Atlantis MAV6000 Top Load Washer
How do I repair a constant water drip into the washer tub? Thank you!
Problem just started and is not causing any leakage outside the machine. Machine fills properly, water just does not cut off entirely.
Graham Bagwill
  • 102 Answers
The water inlet valve has something caught between the diaphram & body or the diaphram is split. If it is the type with screws in it you can pull it to pieces, remove the foreign matter or replace the diaphram if damaged (if you can buy one). Alternately replace the valve.
Posted on Sep 22, 2014
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Maytag Washer
Is the machine belt driven? Look under the washer and see if the belt is laying on the floor. If so, just get a new belt.
Posted on Feb 28, 2007
Anonymous
SOURCE: water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Posted on Sep 29, 2008
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Posted on Nov 30, 2008
Robert Siegel
  • 36 Answers
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
BIKER T
Terence Fourie
  • 909 Answers
SOURCE: water drips into the tub when the washer isn't running
Your solonoid is in need of a service. Tilt the washer sideways after you unplug it and remove the water pipes. Once disconnected, undo a nut or two holding the plate in position.and remove water valve from machine. Possibly you can remove both water pipes from the valve assembly without going in from underneath. Once loose, use appropriate screwdriver or socket spanner and carefully strip the valve. Clean dirty area untill all particles are removed. reassemble and retry..
Posted on May 19, 2010
LG Fuzzy logic 6.5kg WF-T7519PV washing machine.Sensor panel error PE where E is flashing indication with sound.
This PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch. If no water is going into the machine, check the water inlet valve operation.
Apr 24, 2017 | LG Washing Machines
PE error code for my lg washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Mar 15, 2015 | LG Washing Machines
I was going to wash some clothes and the lg machine started going PE
Feb 15, 2015 | LG Washing Machines
PE error on WF 1330TP turbo drum machine
Aug 14, 2014 | LG Washing Machines
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
I have a whirlpool washing machine fully automatic. Foe the past two days water was not pouring in the machine. Seems to be the failture of the solenoid valve.Further, when water poured inside manually,...
the drain pump may be blocked, machine wont fill if there is still some water in the system if it hasnt emptied properly. Remove the filter usualy under the panel at the front, and check for blockage and veryfy pump is running.
Jan 18, 2011 | Washing Machines
Ge profile fridge side by side makes only 8 ice cubes per day
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Nov 06, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Dec 21, 2009 | Refrigerators
Saeco stratos coffee maker started to leak inside the machine. I have cleaned the unit recently. It has been working flawlessly for the last 3 years, and I have brewed about 3600 cups. The water leakage...
HI
There are a lot of things that can cause the machine to leak.
You could have a fitting or tube that is broken.
You boiler could be leaking and needs to be replaced.
You could have a hose connection that has come loose.
You could have a bad seal at a connection.
Until you get inside you will not know? You might want to have someone look at it for you.
Scale is one of the major causes for machines to start leaking. Make sure that your water hardness is set on 4, so you descale more often than not enough, to prevent leakage in the boiler.
Nov 07, 2009 | Saeco Stratos Coffee Maker, Espresso...
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
Maytag Atlantis MAV6000 Top Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
