It's like each horizontal line is a full picture but my screen is filled up with "rolling" horizontal lines. Occasionally, the "rolling" slows down enough to nearly display a full picture but then speeds up again.
SOURCE: LCD TV with horizontal lines rolling up screen
Find someone in an area that the Company will ship to and send them the money to get the replacement board. then give them the shipping address and have them send it to you . I would be willing to help if all it will cost me is the time. You would have to take care of the E-Bay Bill and The shipping costs from my location to yours.
SOURCE: rolling horizontal lines on the display of my plasma tv
if u r connected to an ant. it is due to poor signals from the ant so get a booster or amplifier for the ant.
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
SOURCE: Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
SOURCE: My Panasonic tv displays only a thin blue horizontal line
This is vertical problem. The tv have a cold solder in vertical ic or ic is bad.
