Question about Hisense TC14FS68 TV
How do I fix the irritating shhhshshsh sound on my Hisense TV
The TV was fine with my old decoder with the HD decoder it's problematic
Posted by Belinda Moses on
  • fan80031
    fan80031 Oct 09, 2019
    I quit working my desk job and now,,,I ‘m making $97/Hr working from home by doing this simple online home jobz.i earn $15 thousands a month by working online 3 Hour par day.i recommended you try it.you will lose nothing.just try it out on the following website and earn daily…go to this site home media tech tab for more detail thank you...........http://www.Geosalary.com
Paul Bade
  • 1,666 Answers
Try moving the decoder to the other side of the TV, or farther away. The TV audio circuit may be picking up electromagnetic noise from the digital circuitry in the decoder. Another possibility is a defective audio circuit in the decoder.
If you are connecting the decoder to the antenna input on the TV, the problem may be a misaligned (mistuned) audio modulator output in the decoder. In that case, if you have the option of using a different TV channel on both units, try that.
Posted on Sep 21, 2014
I have a HX32N2176h Hisense 32" LED tv will this TV handle and display HD when connected to a Laptop or Android Box with HDMI Cable?
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
I hope this helps.
Apr 25, 2018 | Hisense Televison & Video
Hisense flash player
Unless you are sure the broadcast comes in HD format you can't.
Sep 13, 2016 | Hisense Televison & Video
Hisense 50in hd tv has no picture but has sound
Sounds like either the CCFL tube (like a mini florescent tube) or the inverter that powers it has blown.
Sep 07, 2014 | Hisense LTDN50K360GUS 50" LED TV...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Losing sound momentarily
Are you using an HDMI cable and a digital box from your cable/sat company?
HDMI supports 2 different audio formats and when using a box from your provider sometimes the tv thinks the other format is available and switches to if for a few seconds.
Try using a HD component cable, they have Green, Blue, and Red video with Red and White audio, if the issue is your TV switching between formats this should fix it.
Feb 04, 2013 | Hisense Televison & Video
Ive had sky hd fitted today and cant get sound on tv hd settings but can on normal sd
Hi it is entirely possible that the sky decoder has not been setup to output sound to HDMI. I assume you are using HDMI lead and this lead goes from decoder to TV.
Aug 13, 2010 | Televison & Video
How to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Dec 30, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
I have a tv (don't remember the make) the volume says it's on 0 but it sounds like it's all the way up. not even the mute button works. i unplugged it and it still stays loud when the screen says it's at...
Not sure whats wrong, maybe a software problem.
I wouldnttry fix it, just adapt, try hooking up a hifi to a decoder or somnething and use that sound, the only irritating thing would be the buzz of the tv volume.
May 13, 2009 | Zenith E44W46LCD 44" Rear Projection...
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
215 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
