Question about Canon Pixma MX420 All-In-One Printer
My Canon MX420 prints blank pages?
I press print and all the sheet comes out with is Page 1 of 1
LifeSizeGuy1
    New Friend:
  • 57 Answers
You may be printing a PDF from within a web page and using the browser's print button instead of the PDF reader's built in print button. Just a guess since I'm not a clairvoyant and have no idea what the situation is. Care to fill us in?
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Posted on Sep 21, 2014
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: Printer prints top 1" of page, then just spits out blank pages
try and click on file at the top left hand corner of your screen.hit print and see what happens
Posted on Mar 03, 2008
Anonymous
  • 6 Answers
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Posted on Mar 20, 2008
Anonymous
  • 4 Answers
SOURCE: canon HL 5040 printer grabs multiple papers to print
try one sheet at a time that may work.
Posted on Oct 21, 2008
luciana44
Lissa Nixon
  • 292 Answers
SOURCE: Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Posted on Oct 04, 2009
Anonymous
SOURCE: my canon mp620 won't print the black color.
I had the same problem, after replacing both black cartridges. I solved the issue by running the print head cleaner. Below is the link to the instructions.
For Mac:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
For PC: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
Posted on Apr 27, 2010
Why does my MX420 stop printing halfway?
Hi . If copies are doing fine maybe is a network or drivers issue
May 17, 2017 | Canon Pixma MX420 All-In-One Printer
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
Canon MF5750--copies come out with black streak (smear) from top to bottom of pages when printing. Changed cartridge and cleaned window.
run twenty blank pages through the printer by printing just a period (.) on a document. Otherwise the sheet should be blank. This is a way of cleaning the toner or inkjet ink from the printer. By the time the twentyth page is printed, the page should be clean. If not, you may have to get the printer serviced. The canon service number is 1-800-423-2366 option 1.
Jan 28, 2010 | Office Equipment & Supplies
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Blank pages
by a different printer, it is the paper sensor and too expensive to fix
Jun 04, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printer problem
Usually it print blank because of wrong page selection. Make sure you put the page you want to print.
Mar 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma MX420 All-In-One Printer Logo
389 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
