Question about GPX KCL8807DT TV/DVD Combo
What channel does the tv need to be on for the hmdi cable to get a signal?
Need to know the channel to set my GPX tv/DVD combo to get a signal for my HMDI cable hook to my mobile device
    Top Expert:
  • GPX Master
  • 76,544 Answers
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
Posted on Sep 21, 2014
I have a GPX TV/DVD combo Model # TDE2280B. I have only used it a few times -- now will not play a DVD even with a external DVD player connected to it -- "no signal" is the only message I get.
Have you tried resetting the set to factory default.
[email protected] or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | GPX Televison & Video
NEED CODE FOR GPX TV/DVD COMBO
The remote control code for the GPX TV/DVD combo player is: 20699 or 20769 (Direct TV) Also try: 0699 or 0769
http://www.gpx.com/owners_manuals/TD730B-IB.pdf
Jan 30, 2011 | GPX Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
My tv box sound is distorted when antenna is connected
If the TV is working with an external signal like a DVD player then the set seems OK on the output but if the signal to the TV is bad then it can bring about the noise in the audio due to poor signal strength.
If the signal is strong then it can be a mistuned SIF- osun intermediate frequency section-. you might have to trim this up.
Sep 25, 2010 | GPX TV6000 9 in. TV/DVD Combo
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
GPX KCL8807DT TV/DVD Combo Logo
150 people viewed this question
Top GPX Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
