Question about Whirlpool LSR5132PQ Top Load Washer
How do I reset my top load whirlpool auto load sensing with triple spray tec. clothes washer?
It starts washing before the water in full
5 Related Answers
Anonymous
  • 261 Answers
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
Anonymous
  • 21 Answers
SOURCE: Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Posted on Jan 19, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
Anonymous
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
Anonymous
SOURCE: Problems with Whirlpool Calypso GVW9959K Top Load
The "LD" error code has resulted in a service call for me once. I watched what the service man did and he took the panel off of the bottom of the machine (3 - 5/16" screws) and then the drain assemply is in the rear of the unit. You must drain with a low height pan such as a dish drain pan. Then he found an wire from an underwire bra in there. This was the problem. $150 later we were good to go. This has happened twice since and I was able to remove this myself. Just be careful and take your time.
Posted on Feb 11, 2010
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Whirlpool W10140920 agitates with no water in the tub
I've had the same problem..3 times in 2 years.
EVERY time I needed to relpace the switch sensor (behind the water temp knob.) It fixes the problem, but continues to happen. I am going to get a new NON Whirlpool washer today.
Feb 12, 2013 | Kenmore Washing Machines
What does sensing mean on a whirlpool cabrio
This means that the washer is sensing if there is enough water in basket with quantity of cloths.
Jun 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer starts agitation during water fill up and after spin cycle ends washer fills back with water and leaves clothes very wet.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Oct 20, 2010 | Whirlpool WTW5850S Top Load Washer
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water level is low
This machine only sprays the water, you may never see the clothes completly covered with water it just sprays the water in intervals. You can download a user guide at whirlpool.com select owner center than literature in drop down menu, requires adobe. Hope this helps
Mar 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
1,378 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
