Thermador SGS36GS Gas Cooktop Logo
A
Anonymous Posted on Sep 21, 2014
Convert to propane
How to convert to propane
yosef
Level 2:
Sergeant:
Champion:
  • Expert 250 Answers
  • Posted on Oct 02, 2014
yosef
Expert
Level 2:
Sergeant:
Champion:
Answers
250
Questions
0
Helped
41693
Points
692
There is usually a kit which changes the orifice for lp. Call an appliance store to seed if they stick it
B3H0...A7X Propane Conversion Burners Flame Straight up
Fred did you convert both the orifices on the burners and the gas valve ? they both need it.
Convert natural gas to propane on JGP945--part numbers do not match manual. orifices are color coded not numbered. Any idea on how to match?
Hi, W/D here.
I can tell you how I have done a similar appliance. I contacted my local propane company. They had all of the orifices, and cross reference guides necessary to convert it over to propane and they did it for free. Contact your local company. If your's won't do it for free like mine, they can surely get you the parts reasonably, and provide further guidance.
Best regards, --W/D--
Please take a moment to rate this solution so that we may continue to improve in helping others. Thanks.
How do I convert my maytag CSG7000CAB gas cooktop
i NEED TO DO THE SAME TO MY MAYTAG COOKTOP DID YOU FIND THE ANSWER YET?
How to convert a Modern Made cooktop from natural gas to propane
it's easy. It's only a matter of changing the jets under the spreader plates. They are reletavly inexpensive but make sure you get a qualified fitter to fit them, it's illegal for you to do it.
Jan 17, 2010 • Cooktops
1helpful
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Converting Natural Gas to Propane
Did one not come with the unit itself? It would be taped to the top. If not then go here.
Here is instructions on how to do it.
http://www.appliance411.com/faq/gasrange.shtml
you can buy the part at your local ACE, Home Depot, Lowes
1helpful
2answers
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
1helpful
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Convert to LP (propane)
Contact Miele directly via their website. This would require an orifice change if it is possible for this appliance. Since natural gas, butane, and propane are all forms of LP (Liquified Petroleum), it is usually, but not always, possible.
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
