Question about HP LaserJet 4250n Printer
HP 425N PRINTER NOT PRINTING CLEARLY
PRINT IS GRAINY BLURRY AND LINES DOWN PAPER
Mark Schmit
  • HP Master
  • 1,915 Answers
Sounds like a bad toner cartridge or a bad fuser. Try a different cartridge and also try running a cleaning page.
Posted on Sep 21, 2014
5 Related Answers
Anonymous
  • 300 Answers
SOURCE: HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
Posted on May 29, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: HP 4200 printing very light, smudgy and blurry
Remove the rear door by pulling it down and squeezing the left tab to remove it.
Press the blue hooks and remove the fuser. Look for a worn coating on the gray roller.
Posted on Feb 20, 2009
Anonymous
SOURCE: I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Posted on May 05, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: while i print a paperon my hp leaserjet 1020 printer i find black spots on paper
It sounds like the toner cartridge is leaking.
Posted on Jun 04, 2009
SOURCE: When I give print it pick up paper and out the
hi
your printer is A4 Size printer it will not print A3 size
if you fill to print A3 go to HP site and support page find your solution
Posted on Jul 29, 2010
It is printing but the lettered is fuzzy
Best practice is to indicate device, brand, and model when querying about printers. Solutions vary by such often.
The blurring could be caused by the type of paper being used. Or, too much paper being in the printer. It can also be caused by substances adhering to the ribbon (where one is part of the setup). Then there is a potential problem with a fuser in a laserjet.
For example:
Printed documents print ghosted blurry grainy doubled or with smudges What...
How to Solve Common Printer Problems
Fuzzy Print HP Laserjet 4240 4250 and 4350 Printers
Aug 28, 2017 | The Office Equipment & Supplies
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. ...
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
In the program being used for printing, click File , and then click Print .
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
Apr 23, 2011 | HP PhotoSmart C4280 Laser Printer
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Missing lines and some lines have only half the characters
Solution one: Make sure the paper is appropriate for the print job Using the wrong paper for the print job might cause the colors to be faded or dull.
  1. Many papers have printing and non-printing sides. Make sure to load the paper with the print side facing down.
  2. Make sure the paper type is appropriate for the project. Use HP Premium or HP Advanced Photo paper for the best results.
Solution two: Check estimated ink level Use the following steps to check the ink level.
  1. From HP Solution Center, click Settings , and then click Printer Toolbox . The toolbox appears. NOTE: The toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences , click the Features tab, and then click Printer Services .
  2. Click the Estimated Ink Level tab.
Solution three: Check the print settings Use the following steps to check and adjust the print settings for the product.
  1. In the software program from which you are printing, click File , and then click Print .
  2. Make sure the product is selected from the drop-down list, and then click Properties or Preferences .
  3. Click the Features tab, and then select the print quality and paper type settings that match the print job.
  4. Click OK to accept the new settings.
  5. Click Print to send the print job.
Solution four: Check for defects using an extended self-test report Extended self-test reports identify specific print quality issues. Use an extended self-test report to determine what is causing the issue. Step one: Print an extended self-test report Use the following steps to print an extended self-test report.
  1. Press and hold the power button (c01346625.gif ), and then press Cancel .
  2. Release both buttons. The extended self-test report print
Jun 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Double Blurry Print
Usually hairs sticking to the underside of the print head causes this.
I gave a solution to an Epson CX6400 user who needed to physically clean his print head. Look this up in the solutions. It involves using folded kitchen roll under the print head with the printer switched off and the head unlocked and free floating.
It would take me ages to type this again so please look this up.
The user had jammed paper and cleared the jam but had paper stuch to the underside of his print head.
I hope this helps.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Jan 17, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
HP LaserJet 4250n Printer Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
