Question about LeapFrog Leapster 2 Learning System
How do I fix a leapster2 that turns off as soon as the warning message comes on?
Have installed new batteries, but unit continues to turn on and shut off as soon as the warning on flashes comes up.
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Leapster2 - turns on but screen dark
at the bottom of the toy,near the headphone jack are brightnest control and contrast conytrol buttons.there u can set brightnest that is good for u.
Posted on Dec 08, 2009
Anonymous
SOURCE: Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries.
Our leapster 2 would not work past the 'Important message' screen. My husband made sure that the DS card was removed first, then instead of turning the unit over and putting the battery pack in then doing the screw up, he actually did it in reverse. He put the leapster unit onto the battery pack. It seems that the batteries slightly move when you turn the unit upside down.
Posted on Dec 26, 2009
Anonymous
  • 30 Answers
SOURCE: Leapster2 shows low battery but the batteries test
Use regular batteries not rechargeable ones
Posted on Jan 13, 2010
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
The screen is not responding
You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Feb 01, 2011 | Leapster 2
When you press the screen it dosen't work. Batterys are in a good place i don't know what to do is a brand new toy
6) Restart unit
Jan 25, 2011 | Toys
The styler or pen or whatever you call it is not working. We press on the screen and nothing. What does that mean?
Maybe you need to calibrate it. Calibrating the Leapster2 is easy:
6) Restart unit
Source: http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Jan 22, 2011 | Leapster 2 Handheld Game
The stylus pen does not work
6) Restart unit
Jan 20, 2011 | LeapFrog Enterprises Leapster2 Learning...
My leapster 2 won't let me write my name in the screen?
6) Restart unit
Jan 15, 2011 | LeapFrog Leapster 2 Learning System
After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
6) Restart unit
Jan 13, 2011 | Leapster 2
The touch screen ain't working
Try to calibarte it:
6) Restart unit
Source:
Dec 26, 2010 | Leapster 2 Handheld Game
I can not type in names to activate this toy. I touch the screen and nothing happens.
I think you need to calibrate this toys:
6) Restart unit
Dec 24, 2010 | Leapster 2 Handheld Game
Our brand new leapster2 has
you could try this....
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 21, 2009 | Leapster Learning System
LeapFrog Leapster 2 Learning System Logo
218 people viewed this question
Top LeapFrog Toys Experts
Marvin
Marvin
Lawrence Oravetz
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
