It laggs especially when im doing school work and it costs me detention and icolation and susspended and i could get expelled beacause my homework isnt getting done beacause my internet is lagging please sort it out or i will sue youre company.
If the lag in internet connection is your main problem, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
If it only lags at home, then I would say your internet is slow.
If it lags no matter where you are, then you need to run some maintenance software to clean it up. Try going to iobit.com and downloading Advanced SystemCare. It goes through and detects all sorts of problems and fixes it, for free. I've used it on hundreds of computers, and its successful a majority of the time in speeding up a computer.
SOURCE: Lagging
if it is only while during online play then it is your internet speed connection is too slow if it all the time while playing the game wether it be on or offline then your graphics card is not advanced enough to support this game mainly because of the amount of graphics ram on your card try upgrading to a new graphics display card! i hope this helps!
SOURCE: sooooo laaaaggggg
Please try to run this system in safe mode and see if it starts up faster.
XP Goto start and select run then type in MSConfig. Navigate to your startup tab and disable the ones that you don't need.
Vista Goto start and type in msconfig and doubleclick on the icon that appears then Navigate to your startup tab and disable the ones that you don't need.
Please check this post - another fix of mine for slow systems
SOURCE: Hello, My vaio pc is
Start your pc and and check if the fan it runing (try to hear the sound) If not, replace the fan. But first check if you still have garanty.
SOURCE: Well, my ASUS X71SL-B2 17-Inch
Here's a list of most common tasks you can do to speed up your system.
1. You need to scan your system for spyware and malware. go to http://www.msbin.com and check out the spyware and malware catagory.
2. Make sure your hard drive have enough free space.
3. Make sure your system have sufficent amont of physical memory.
4. Run a defrag on your hard drive.
