Bosch WAE20060UC Axxis Series 24" Front Load Compact White Washer Logo
A
Anonymous Posted on Sep 20, 2014
How do i start my w/m when always show a small key on the screen?
WHEN I DRY TO START the w/m the screen show 0 and red small key make noice
Lloyd
Level 2:
  • Expert 89 Answers
  • Posted on Sep 22, 2014
 Lloyd
Expert
Level 2:
Answers
89
Questions
0
Helped
35321
Points
136
Child lock activated, press and hold start button to de-activate it
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
TRY
Press 0-8 then enter 400 and make it 0 then press print switch, if it doesn't work you have to change the thermostar, then if not working change heater, it not then IH board, and the last solution is to change the system board.
OR TRY
This problem is caused by the thermostar in the fuser section. To reset shut machine off, then turn it on while holding doen the 0 and the 8 key down for more than 10 seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a number in the screen, press 0 then start key this should reset the code if not the themostars need to be replaced.
How to reset pm counter toshiba es 356
Power "OFF" the copier. Press continously "0" and "8" while turning on the power. From the screen it will show AD mode. Press "252" then "Start". It will show some numeric values on the screen, " this is the past PM count ". Press "0" then "Start" or "Interrupt " key then power off and on the copier ..
Richo infotec 3090 SC 593
- Toner Suction Motor Replace Alert.
- The total operation time of the motor exceeded 600 hours.
- The toner suction motor has reached the end of its service life.
- You can try rest it, after some time it will start to print light prints.
- So you will need to replace it.
- You can clear the code in Service Mode.
- To enter into Service Mode you need to follow the next procedure:
- Press the following key in the following order:
1. Press Clear Modes [yellow key] .
2. Press 1 - 0 - 7 [ with the blue keypad numbers ] .
3. Press and hold down Clear key [ C key] for 5 seconds.
(after release of the C key, the Touch Screen will change)
- On the touch screen press the [Cop SP] .
- Press the following number with the blue keypad:
[ 2 - 9 - 7 - 3 - 0 - 0 - 1 ] then press [ # ] .
- On the right side of the touch screen should write the following:
[ Toner Suction Motor Operation Time ] .
- Press [ 0 ] with the blue number keys, then press [ # ] .
- After doing all of this re cycle the machine by turning it off,
wait for 10 second, and then turn in on with the main power switch
[Red Power Switch] .
----------------------------------------------------------------------------------------*note: the machine will work again with this procedure but maybe,
after some time, or maybe even immediately after this,
the machine will start to make light prints.
How can I do to show on the screen the activation of the caps lock key?
You can "hide" or "show" it from the notification area via:
Start > Settings > TaskBar & Start Menu > place a check next to "Hide inactive Icons", then click Customize, Located the items and you will see a drop down menu appear. Select "always hide" or "always show" and click OK > OK.
Car will not start
Could be a dead cell or bad connection if you have a voltage gauge in your car try to start it and you will see the voltage drop from normal to 0 if this happens have your battery tested if that's fine check your connections if those are good have your starter tested.
1helpful
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
My photocopier (toshiba e-studio 720) can't start. When turn on power, on the screen i only see icon start. It can't not start. Tell me why and way to repair it, please Ngo Hieu.
how are you this is jack my id [email protected]
Yor copier e-studio 720 can t' start,
Dear you press 0 and 8 key and on your copier other hand.
Then copier on then you press 690 and stars key.... copier screen show 2.... 2 then you press enter (on toch screen).
after some time copier screen show REBOTE THE MACHINE.
THEN torn off ... and simple on the copier ..
PLEASE VOTE ME
Best Regards,
Thanks,
2answers
I have a toshiba estudio 200l wuth perform preventive maintenance on display. How do I clear off of screen?
turn off power
hold down 0 & 8 keys
turn power on with keys still held down till beep is heard
enter 252 then press start key
enter 0
press enter icon on display
power off & on
should clear service message
1helpful
VCR keeps showing "F03" and doens't do anything
Your vcr seems to use the K Mech. F03 Means that the mechanism locks when unloading.
The cause of which might be the loading motor or drive, timing and most likely the mode switch.
Sometimes will not start and digital dashboard stops working.
Just had this problem on one of my homies cars. We thought it was the fuel pump, but it wound up being the anti theft. Locking all the doors and unlocking it from the drivers side (As recommended in the owners manual. ) with the key didn't work. But it did work locking all the doors and unlocking it with the key from the passengers side. Started right up!
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
