It just stop running, was fill of dirt and dust. I dump the dirt and clean the filter
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: filter clogs with every use
What should I do when the dirt Devil Vacuum clener doesn't **** up dirt ?
SOURCE: vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
