Need a manual for the Midland swr meter 23 - 136
SOURCE: look for schematics for a midland cb
daniel, first off, I need a complete model number for the radio info. Midland only made about 40-50 different models over the years. The header calls for a 75-822 and you are asking for a ** 833. The beginning should be a 13 or 75,76,77,78. Let me know the # and i'll be able to get you the proper pinout.
Thanks,,, Mechanic
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
SOURCE: Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
