Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-57HW40 Error Codes 6 & 8
About six months ago, my Sony KP-57HW40 started flashing red and then turn off. The Timer/Standby LED flashed 8 times. If kept turning it ON several times, it would eventually stayed on and worked normally. About a month ago, I started seeing curving red lines across the screen when the background was black. Today, it stopped working - no picture with a moment of light blue screen and it flashed several times then turned itself off. The LED now flashed 6 times. I opened the rear panel and noticed that the RED CRT was not working at all!
I am an electronics engineer but have never worked with TV. I am afraid that my problem is more than the FBT, as I read from the previous posts. I hate to give it up yet. I really need helps. I would appreciate any suggestion. Thank you.
Posted by Albany Guy on
  • 5 more comments
  • Albany Guy Dec 16, 2007
    Pridah,
    Thank you very for the solution. I actually bought a Panasonic 56" LIFI HDTV on the Black Friday. I disassembled my Sony KP-57HW40 and save all the electrical/electronic subassemblies because I hate to just threw them away. I know some of them do not function properly. If anyone needs the parts, I can ship them to you but you have to pay for the shiping cost.
    Thanks again.
    The Albany Guy.
  • Anonymous Dec 18, 2007
    i have a sony kp-57hw40 built in 2002. once a weed arched red lines pop up then bright red flashes, then powers off. today i had back off and tapped on crt's, no effect. however, now green lines pop up then bright green flashes, then powers down. i'm guessing the crt's are good, and that the red is not shorting out, or am i off base with deductions. would like to pull a board and check solder, but not sure which one to go after.
  • Rusty273 Mar 18, 2008
    My tv flashes blue then shuts down red light flashes 8 times on front of set . I can restart and the picture will be pale then eventually brighten and become normal . Looks like I'll have to trash it if it goes or I can fix it my self on SS now no money for the repair guy .
  • TEXOID May 19, 2008
    I NEED THE RED PICTURE TUBE FROM A 57HW40. CAN U SPARE IT?
  • kahunagirl Sep 29, 2008
    The red and green crt failed. I'm looking for replacement parts.
  • ranger_4387 Mar 23, 2009
    my screen actually sometimes while watching will go blue and then turn off, someone told me maybe need to replace blue tube, so if you have that let me know I will pay the shipping. my email is [email protected] thanks
  • jeff_mull615 Mar 30, 2009
    I have a sony 57'' hd projection tv. tghe screen flashes a couple of times and then it turns off and the red led light blinks 8 times. I was told to buy a new projector bulb and the crt that conects to the bulb, but I can not find them anywhere because my tv has been discontinued. Can anone help me and tell me where I can get one at or if you know any one who has a extra tv like mine that they are trying to get rid of. If so my Email is [email protected] Thanks alot.
Anonymous
Just fixed my arching green lines on my sony kp46wt500 used the info at somelifeblog.com great info and step by step instructions. if you can use a screw driver you can fix this problem in 20 minutes from start to finish
Posted on May 17, 2008
Anonymous
    Problem Solver:
  • 10 Answers
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Dec 15, 2007
  • Anonymous Dec 17, 2007
    Hey Albany Guy,
    I actually need a new speaker screen. The entire bottom portion of the speaker and plastic surrounding. Do you have it available? I'll pay the shipping. Please let me know. Thanks.
    Pridah.
    P.S. here is my email address, [email protected]. Let me know.
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57HW40 57
Sounds like a convergance amp problem or possibly the S.D.K.'s are going out
Apr 20, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57 in
Bad blue CRT ...........common problem...........T.
Nov 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
2,701 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
