Question about Mitsubishi VS-60607 TV
MY TV TAKES AWHILE TO HEAT UP TO STOP WAVE LINES
I TOURN ON TV AND HAS LINE UP AND DOWN, AFTER IT STAYS ON FOR AWHILE. IT GETS CLEAR AND NICE
Posted by f castro on
1 Related Answer
Eric Miles
  • 15 Answers
SOURCE: DISTROTION, TAKES AWHILE TO GET A CLEAR PICTURE
Projection tubes need replaced. They will only work once they are warm, so they are wore out.
Posted on Sep 20, 2014
HUMIDASTAT INTERNAL RED LIGHT USED TO BE ON AND UNIT WORKED. LIGHT STAYS OFF AND UNIT DOES NOT WORK. WHEN I DISCONNECT AND REATTACH HUMIDISTAT POWER LINES, RED POWER LIGHT GOES ON FOR A SECOND AS DOES THE...
will not blew very good heat and shut down with stop light came on it dose work for 30min after i drain the water but it go back to the stop light again then the will for about1min or so then it shut again
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Glitchy picture with lines across screen when turned on
I can give you detailed guide describing exactly wich capacitors to replace . Your tv really only needs maybe 5 dollars worth of parts. But you must know how to solder and take things apart . also you must be able to put it back together. if only there was some way you could paypal 50 buck to me.;(
1helpful
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
5helpful
3answers
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
1helpful
Vacuum stops
Your thermal cutout is tripping. This only happens when the motor heat gets very high, and the reason it takes a while to turn back on is that the motor has to cool down before it will reset. Ensure that absolutely every air pathway is clear, because a lack of airflow will overheat your motor. If they are, you have probably blown a motor bearing, which unfortunately is not economically feasible to repair since it requires a whole new motor.
-R
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
 Grubhead
Grubhead
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
