Question about Wolf Range Ovens
How do i find the fuse location for a Wolf double oven, Model D030F/S ?
I heard a pop when starting it, and none of the elements work in the upper unit( double oven)
Posted by mtb6246 on
Jose Mendoza
    Sergeant:
  • 199 Answers
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
Posted on Sep 20, 2014
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
The broil unit in the upper oven of a GE double oven does not work. The heating unit has continuity, 17.5 ohms, when connected, but that should be the resistance of the unit itself with all switches off....
the broil element doesn't get 240 volts,it's 120.also you should have the oven unplugged,pull out the element and read it out or at least one wire has to be removed from the part you're checking for continuity
Oct 02, 2010 | GE Ovens
I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
Heard a pop/bang and now no heat
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
Warming up, big POP sound and totally stopped working.
Hello- Wow-  Sounds like the failure of one of the elements.  Sometimes there's a bright arc welding flash with it too. Look inside oven with flash light and inspect elements. If one of them is burned through, then it must be replaced. In some instances, control boards and other circuits can also be affected, but most work just fine when the element is replaced.     Please acknowledge this posted solution if helpful.                                   Have more info if needed- thanks-  Ed
Mar 24, 2010 | Wolf Range Ovens
Ovens Logo
208 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
