Printing same pages of fax information, if we put on standby, will continue only after turn on
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: ricoh 1045 only printing on 1/2 page
Check the glass **** next to the area you slid the developer unit into. Chances are it is half covered with toner.
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
SOURCE: My Ricoh Laser Printer is not working
For to use the network printer first of all you should have a network connection port.
If you have one on your printer than you should install a driver on the computer from where you will print then connect the cable with network LAN cable which the one end is connected into the printer and the other into the network switch or router. After this is done go to start menu on you computer than go to printers and faxes and select the printer driver 1515 press the right click and click on properties then go to port and create a TCP/IP port similar to the computer ip address.
EXAMPLE:
if the address on the computer is 192.168.0.100
than put the address of the printer as follow
192.168.0.101
Please look at the paper sheet which is printed from the machine by her self when the machine is turned on for the first time in the day.
There should have a port name which can be 10001 or 9100 or 9101 or similar.
Enter that number in the TCP/IP port properties than go to the machine and press the [User tools/ Counter] key then go to system settings and than network settings and enter there the ip address which you had enter before on the driver in the computer.
SOURCE: Ricoh MP 3350 Fax Report
Hello sir; You may go to hit the user tool key on upper left corner of the control panal, the go to fax setting then go to reception page, you may change information you want.
